I am an industrial designer and machinist. Currently I am using Rhinoceros as my modelling software with the RhinoCAM plugin attached to handle my machining needs. I am a proficient SolidWorks user, however I prefer not to use SolidWorks and all other CAD/CAM packages that I have come across because how fast I am able to move through the Rhino3D interface.
In Rhino I am able to type the command of almost any feature that I can think of or use on a daily basis.
In the attached photo I am sweeping two curves to make a surface, in order to do this the only actions I have to perform are as follows:
1. Type "sweep2" (if I have used this command a few times recently, I don't even have to finish typing the command)
2. Press "Enter"
3. Follow the instructions to complete the command
4. Press Enter
This entire process takes about 5 seconds MAX! It is for this reason I use a one handed keyboard.
Please incorporate a command line. This would be the most beneficial addition to Fusion360 in my opinion.
Thank you,
Joseph L. Kabenji
