colour code in draft analysis
the colours used in a draft analysis are neither explained with a colour code, nor changeable.
At lease a colour code/scale would be very useful, especially to export a screenshot.
Thanks!
2 Comments
moriarty.chch
I do casting design - setting and controlling draft is critical - this tool is marginally helpful and definately not intuitive.  It kind of works and thats all you can say.
  • what do the colours mean?
  • what does tolerance actually do and how would you use it?
  • being able to flip the draw direction would be helpful
ALL the inspection tools need to provide sufficient information on screen to generate a graphical report - this can be snipped from the screen and pasted into a design document. Not this tool.
Hi @moriarty.chch,
in case you don't have the info, here is the colour code:
Green = OK along positive value vector
Yellow = Tolerance zone between red and green
Red = Not OK along either chosen vector
Turquoise = Tolerance zone between red and blue
Blue = OK along negative value vector
