Change to the 2D Drawing Tolerancing interface.
When i'm generating 2D drawings out in Fusion, and I go to update the tolerances when i click on the input field, then go to type if my mouse has moved out of the immediate area it starts typing elsewhere in the window usually on the drawing, it's kind of annoying trying to type stuff in with the num pad and use the mouse at the same time with this current setup. It would be great to lock the keyboard into the field until you click elsewhere or hit tab like the rest of the program, Thanks in Advance.
