When using tools where multiple selections are required it would more efficient to change inputs with the tab key instead of clicking on the next input box.
For instance the Mirror tool requires Objects to be mirrored and a Mirror Line. the Objects input is selected by default, but to switch to the Mirror Line input you must select it with the mouse. Using the tab key would speed up the process.
-Jake
