Show only
Search instead for
After stop sketch in fussion360 there should be some feature in software which can change dimension of design in 2D by just double click on the 2D DESIGN like we use in catiaV5 and other software.
It is possible to edit sketch dimensions without re-editing the sketch, use the 'Change Parameters' panel on the 'Modify' menu. This is particularly useful because the changes you make are instantly visible as the dependent geometry is updated real-time.
hi @fredgenius i knew that we can edit sketch dimensions but i am saying is to just double click on the 2D DESIGN and we can change the dimensions because on working on a project we have change dimension many times after completing it.
