Change Dimension Landing Line in Drawing
When creating a line, Fusion 360 makes you zoom way in to place the end point. It is impossible to be exact. It should stop once the begin point is set and let you set exact dimensions and angles. An OK can ask for the next start point. This one problem alone wastes huge amounts of time and created inaccuracies that show up later. This feature alone makes the product unusable for exacting work.
2 Comments
daniel_lyall
I think you need to go through the learn section
I searched for how to do this. I will see if I can find it in the tutorial.
Thank you for the pointer.
