Change default units after part creation
Need the ability to switch back and forth between units at any time. Parts are stuck with default unit settings. Need to be able to toggle between unit settings on existing parts.
6 Comments
TrippyLighting
This seems to be clearly a bug as that has been possible before.
HughesTooling
Can start a thread in the design section and upload a file where you can't change the units.
Example where it works for me, files in mm.
Units changed to inches.
TrippyLighting
I tried this as well on a couple of parts. To my surprise changing the units works in one of them, but not in the ther. I have not figured out what might trigger this. Will start a thread later.
kb9ydn
Overall, units management in Fusion is hit and miss.  Most things work but a few things don't.  If you like to always do everything in mm you're set.  Otherwise not so much.
C|
colin.smith
This item has been archived due to a lack of votes. If you feel this item is important feel free to create a new idea station item.
colin.smith
Status changed to: RUG-jp審査通過
