CAM posting output folder
I would like to suggest the CAM software remember where a previously posted file is located.  I regularly jump back and forth between CAM files and the Output Folder only remembers the location it was pointed to the last time a file was posted.  I post my CAM files in customer named folders and sub folders with part numbers.
Example
I post a file for customer "123" and then work on a CNC program for customer "456".  While working on "456" I need to go back to "123" and post again.  Now the Output Folder is now pointing to "456" location.  Sure would be nice for the software to remember where "123" is since I have already posted to the "123" location.  This would save time so I would not have to browse back to the location I want the file posted to.
2 Comments
This is what I am missing too.  If the output folder can linked and remembered within the fusion file.
Luke.Hicks430
Additionally, when you have to change which post processor you are using (for a different machine), Fusion resets your output folder location. The Output Folder location should be independent from which processor you use, as will as saved with each part file.
