We use the 5-axis swarf tool with multiple passes for virtually everything, which results in multiple instances of the same tool path. This means we're cutting air for most of the time with the initial passes.
It would be good if Fusion were able to optimise the multiple passes option by trimming the tool paths as soon as they exited the stock (resulting in less wasted time).
