Whoever coded the CAM speeds and feeds knew what they were doing. I almost never tune feeds and speeds when cutting aluminum. Great job. Would be very helpful if we could get a material selection menue that throttles the speeds and feeds based on the material you are machining. Plastic increases feeds and speeds by 50%. Aluminum is good. Steel, we throttle back 50 - 75% and slow down speeds and feeds and step depths.
Keep going, great stuff.
Pat Conarro/Founding Partner DFMXpert: Tooling & Technologies
