This one is easy. Just some clarity in the help menu for "Touch Surfs. When I mill on a 3 Axis CNC, my undercuts get washed away. See the mold photo below. The CAM path follows the undercut with a ball end mill. I just found touch machining, and it appears to have solved the problem. Can we update the help when you hover over the Touch Surfaces buttons to include the language that states that Touch surfaces are also used to aviod machining undercut surfaces from the Z direction"
The CAM path is right when touch surfaces are used.
