CAM > 2D Pocket > Geometry tab needs "Select Same Diameter" function
Since CAM > Drill > Cycle > Circular Pocket or Bore milling options don't automatically import the correct size hole from the model, I would like to see the "Select Same Diameter" functions from those options applied to the 2D Pocket > Geometry tab to make it easier to drill multiple holes with an endmill.
It is very tedious to select 120 holes click by click . . . .
Please either fix the drilling cycles, or add this functionality to the 2D Pocket > Geometry tab.
