There needs to be an improvement for naming posted CAM files. Please add an option for the default "Program name or number" to be other than "1001". It does not make sense to have a file name that does not indicate what part it is associated with. I understand that you can type in an alphanumeric name if your post supports that but it is a nuisance task to retype the part name every time you post your program and it is prone to error.
I suggest adding a default file name option that would be user defined according to a hierarchy of selected options (or have the option of just using the same name as program number, Oxxxxx, for those who prefer to keep this naming method). This could include Program name, Machine name, Setup name, User name, Operation name, Revision name, etc. Depending on the order that options are selected would determine the default name of the posted nc file instead of "1001". The user then should be able to set a default program number (Oxxxxx) or use a user defined program number from the post process interface.
Example
Program name: default (programName_machineName_setupName)
Program number: default (O0001)
Program comment:
