CAM - Allow save of NC output folder if changed from default
Please provide an option to define the default NC file output folder.  It's inconvenient to have to modify the location every time you generate a POST.
1 Comment
HughesTooling
You can set the default post folder for each post you use. Just click the box at the end of the input field and set the default folder.
Mark
