BUG REPORT: Splitting body using extruded sketch
I have a model made in Catia (iges fileformat).
I imported it into Fusion 360, stitched the bodies together, created a sketch using lines, extruded and used split body feature.
This fails miserable, it's more like an intersect.
Creating a box, and using that to split body works exactly as expected however.
I needed a sketch because it's a large object i needed to split in two with puzzle pieces, and sketching a line is the best way to make something that just snap fits together. A 0.05-0.25mm tolerance is required for the pieces to fit together nicely.
3 Comments
Seconded. I run into that so often I forgot it was a bug.
Split with the face of a body [fail].
Create construction plane coplanar to the exact same face and split with that [success]
Super annoying.
colin.smith
This item has been archived due to a lack of votes. If you feel this item is important feel free to create a new idea station item.
colin.smith
Status changed to: RUG-jp審査通過
