Browser management option
I imported a model created in Rhino and none of the hierarchical structure reamains intact.  I end up with a list of hundreds of bodies.  When I try to regroup the bodies into logical component folders I have to highlight the bodies in the model, find them in the tree and then drag them to a created folder, however the folder name is always a good distance away from the selected bodies and requires a long scrolling chore.
It would be useful if there was some way to designate destinations for any number of items that would remain inside the working window.  Perhaps a second (perhaps temporary) column(s) could be called up for such a purpose and then when finished disappear leaving the single browser tree behind.
On the other hand, the browser tree can get a bit unwieldy on any extensive modeling project.  There's probably room for improvement here.
http://www.screencast.com/t/AT235QaYNl
4 Comments
innovatenate
Autodesk Support
It sounds like you're looking for the Group Feature or the Move to Group feature? Take a look at the below screencast.
http://autode.sk/2f9eNUv
keqingsong
Status changed to: RUG-jp審査通過
keqingsong
Status changed to: Gathering Support
We are working folders for bodies in the browser and the work is slated for this upcoming update. Next phase is to make it work for components.
keqingsong
Subfolders within the Bodies folder is now available! http://www.autodesk.com/products/fusion-360/blog/march-1-2017-update-whats-new/
