Show only
Search instead for
Such a pain this is not done. I have a model I want to import into a new project and I don't want the gazillion components which go with it, just the model, so I have to break each link, one by tedious one.
I would love this feature as well. Sometimes I like to create a copy of a design to do "what-if" studies. I don't want to worry about affecting the original design so I save a copy and then break all of the links. Breaking links is too much work in Fusion.
There should also be a command to make an isolated / unlinked copy that does this for you. A simple check box when you save-as that indicates you want all links broken would be great.
In version 2.0.5827, It is possible to select multiple link items and break them. I have do disable the history first, and it take some time but it seams to work. The key might be to right click on the outside of the component side bar. Otherwise it only breaks the like of the clicked item
