Branched\multiple Pipe
It would be useful if you could select multiple paths with branches for the pipe command. Also allow selecting multiple paths that don't touch. It would help laying out waterways and runners in mould tools.
Screencast example done in Rhino.
Mark
2 Comments
cekuhnen
Very much agreed! Currently the pipe tool is limited to single commands in the timeline which will blow up the timeline significantly if you use the pipe command s lot in sequence
promm
@HughesTooling,
Thank you for your idea, this is getting changed to future consideration.  Right now you can select multiple segments when using the pipe tool inside of T-Splines.  The modeling pipe tool is actually limited by our chaining selection capabilities, which is something that we are working on improving in the future.
Cheers,
Mike Prom
