This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Better Thread Mill Tool Geometry
1. If I'm setting up the tool correctly, the first line is called "Diameter" but I think it should be more specifically labeled as "Cut Diameter". Yes I see it says "Cutting Edge" right above it.
2. The tool's Neck Diameter appears to be automatically scaled based on some calculation using the "Diameter" value. This has caused some confusion for me when setting up a tool, and when I simulate the cut I tend to get interference (red) which makes me nervous. I've worked around it though. You'll see in the image below that the cutting geometry is tiny, and disproportionate to the Neck Diameter of the tool I'm holding in my hand.
My tool is the TM8 at: http://www.abtoolsinc.com/pdf/Solid-carbide_Thread_Mills_and_Chamfer_Cutters-AB_Tools_Inc.pdf
I would like to have the ability to specify the Neck Diameter and the Cut Diameter separately. And while we're at it....
3. I would like to be able to specify the "Crest" too (see above link).
2 Comments
russtuff
Now I'm not sure I have this right (mostly because I don't think the labels are clear). In my model, my holes are the minor diameter. I assume that should be the correct way to model a hole to be threaded.
The "Diameter" at the top of of the tool settings is either the Cut Diameter or the Neck Diameter. I'm not sure and don't want to break tools testing it out.
cj.abraham
Status changed to: RUG-jp審査通過
Use these settings in the pictures. We will make incremental updates to the thread mill tool definition, but this will work. The key here is to use the Shaft definition settings to create segments for the tool shaft.thread mill 1.pngthread mill 2png.png
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
