Show only
Search instead for
Previously when you sketched several line segments ending in the same point, each line segment hat it's own 2 end points.
so if you drew three lines starting at the origin, you had 4 points to select from. Three line end points and one origin point.
Not that is not always the case. Some of the line end points seem to merge, so even if you drew two separate lines, you may only get one point to select and 2 line segments highlight.
