better selection of sketch points
Now - it is not possible to see What point you are selecting
Idea - dotted line to indicate which Line the point is related to
12 Comments
HughesTooling
I'll vote on yours if you vote on mine.Smiley Happy more votes the quicker we'll get it.
http://forums.autodesk.com/t5/ideastation-request-a-feature-or/selection-highlighting-enhancement/id...
Mark
@HughesTooling I'm happy to see your similar idea has been accepted 🙂
TrippyLighting
I voted for both ideas!
maritza.ga
Status changed to: オートデスク審査落選
HughesTooling
I see this is in the latest release, not sure when it was actually implemented.
Mark
HughesTooling
It's not a fix bot a new BUG
Now you are not aloud to select just one point !
TrippyLighting
While there clearly is a new bug, this idea also clearly has been implemented 😉
HughesTooling
How do you select just one point ? is not possible in the newest release... BUG !
__________________________________________________________________
Sorry you are right 🙂
HughesTooling
@Anonymous
I don't understand what you mean. I just made a screencast to help someone on the forum and it seems to work, what am I missing.
Mark
TrippyLighting
Previously when you sketched several line segments ending in the same point, each line segment hat it's own 2 end points.
so if you drew three lines starting at the origin, you had 4 points to select from. Three line end points and one origin point.
Not that is not always the case. Some of the line end points seem to merge, so even if you drew two separate lines, you may only get one point to select and 2 line segments highlight.
HughesTooling
Ah I see, Now you have to delete the coincident constraint that's automatically created then you get individual points,
Mark
Sorry you are right, no bug !
The new version just automatic joined points Together
http://autode.sk/2dJcpWa
