The Default angle that is called out in the bend table in the drawing is the outside angle. For the Trumpf press brake I need to be able to label the inside angle. For me this is critical in MFG drawings for the shop floor. I can enter it manually but I rather the software drive the call out instead of me to avoid human error. Is there a way to do this or does this need to be an enhancement request?
On the attached .pdf it shows the bend table calling out 75 degrees for bend 4 which I need to have 105 degrees and 95 degrees for bend 3 which I need to call out 85 degrees. If my operator were to enter 75 and 95 respectively I would not get the profile shown.
