Being able to switch distance direction in the chamfer tool..
dpar15 brought this to my attention, you can't switch the direction in the chamfer tool when using the distance and angle. I'm sure a lot of people need this. I know I am one of them. I know there are work arounds but it wastes time.
77 Comments
Please add this It's killing me trying to create a shaft.
promm
Thank you for your idea, this is getting changed to future consideration.  When work gets started it will be changed to accepted.
Cheers,
Mike Prom
dannyspitz
this is a standard in every other CAD tool i've used. fundemental for a quick work flow! Please get this in to the next build!
I have the same problem.  It is only a small thing, but it can be a real nuisance.   I am used to Pro Engineer Wildfire and there if the chamfer is not the way you want it you can flip it.
I absolutely agree with this suggestion. its very inconvenient to have to calculate the distance when the direction is wrong. Please make the feature available as soon as possible.
susibiker
Driving me crazy (new to F360 and this kind of CAD in general - drawing board only until now), so how can I do this? What are the workarounds? Geometry calculations? How?
I just had to go back to the sketch and draw in the chamfers manually.
There's got to be a better way, right?
TIA,
Susi xx
Trigg3r
This gets a thumbs up from me, currently driving me crazy.
nick.wimpney
I just ran into this one too.  It seems silly that there's not an obvious way to flip the direction
this is driving me crazy to edge next to each other both Chamfer is different direction when using the Chamfer Angle option ?? Please add a fixes AD
This is a real pain, please fix ASAP
susibiker
I know you guys have done so much with Fusion 360, and I totally applaud this feat, however, people have been asking for this for YEARS!
Please can you see your way to adding this minor feature - this is making tidying complex objects a nightmare.
Thank you kindly.
Susan xx
Count my vote for this little rectification, which is so desperately needed...
How is this post from 2015 and STILL there's no way of flipping the direction of a chamfer????? Common fusion team get it done!!
Is this still being considered?
susibiker
I'm guessing >>> NOT. 😞
coryh83
Community Visitor
How is this still not fixed???? this should have been a simple addon and is a critical feature needed when working with shaft chamfers. Get this done ASAP please
ymif1
i had the same problem, fixed it by using the draft-tool instead of the chamfer-tool. But i agree it would be easier for users to have the option at the chamfer-tool.
So i hope it will be fixed soon, otherwise (or till then) maybe somebody else is helped with the draft-tool.
Ruud
Voted this up in hopes they add the button.
DWhiteley
Come on guys - it's about time this was sorted!
