Avoid surface, AUTOSELECT!!
In 3D toolpaths I use avoid surfaces all the time and it's very time consuming. Can you imagine how nice a check box for select all unused surfaces would be? I can!
Please please please make this happen. It's senseless to individually pick surfaces not to touch. Just grab every surface I didn't select as a drive surface.
1 Comment
HughesTooling
What you're doing there with model selection looks to be bad practice and could be quite dangerous. The op will only see those surfaces and totally ignore the rest and you risk machining the anything not selected or worse rapidng through. I suggest you make some posts in the CAM forum preferably with designs you can share for advice on how best to work with Fusion CAM. What you're doing looks like the wrong workflow.
Mark
