Automatic GRBL M5 Command at the end of a project?
Greetings!
I recently started using Fusion 360 as a Hobbyist with an Inventables X-Carve 2.0 running GRBL.
If there's one thing that I'd like to request then it would be the option to include the GRBL M5 command at the end of a Project like how it's already being done with M9.
M5 shuts off the spindle - Something every CNC should have 😉
M9 shuts off the coolant - Rarely any GRBL CNC has this feature.
Code Example:
G2 X-25 Y73.62 I8.62
G1 X25
G2 X33.62 Y65 J-8.62
G1 Y-65
G2 X25 Y-73.62 I-8.62
G1 X-25
G2 X-33.62 Y-65 J8.62
G0 Z59.5
M9
M5
G28 G91 Z0
G28 X0 Y0
M30
This is the end of a Fusion 360 GRBL File I receive which has the default M9 and my added M5 commands in it.
Could we have this M5 also be added by default into the code generation? - Would add a little quality of life to it ;D
2 Comments
sales
Anyone find a solution for this? Maybe edit the grbl.cps?
Autodesk just released a new Fusion 360 post with your request added. See the link https://cam.autodesk.com/hsmposts?
