Automatic Extrusion Setting
When extruding a sketch, you can click on another surface to extrude up to that surface.
Currently the extent menu stays on 'distance' unless changed manually when you do this.
Would save 2 button clicks if the extrude tool automatically changed from 'distance' to 'extrude to surface' when a surface is clicked on for reference.
