Auto tolerance detect
I noticed that when using patches often is not possible to stitch because the tolerance.
We have to play with numbers to find the right tolerance.
Probably the patch feature is not very accurate. I think we should decide at what resolution the patch must be executed or Fusion360 should suggest the best tolerance.
regards
3 Comments
cekuhnen
Well the auto tollerance in my opinion is a tricky thing. Because you can stich seams which are not matching as well.
Maybe better would be a naked edge detection tool and if there is a problem match the edges so the poly surface is really water tight.
brianrepp
Status changed to: Gathering Support
promm
Status changed to: RUG-jp審査通過
Thank you for idea - this is getting archived due to lack of votes.
