Attached Canvas Point-to-Point Scale and Rotate
The ability to insert and scale an image is very useful, but moving the image to the origin and (especially) rotating the image to exactly the right orientation can be very fiddly.
A second "calibrate" option which works like a "point-to-point" move would be very useful:
  1. Pick a point on the image
  2. Pick the corresponding point on the sketch
  3. Pick a second point on the image
  4. Pick the corresponding point on the sketch
Then the image is scaled and rotated so that the selected points coincide.
5 Comments
HughesTooling
This definitely needs improving. I don't know if you've figured out how to do this accurately but I did a screencast for someone a while ago, see below.
Mark
Your screencast is very useful, thanks!
stevsmar13
Thanks for the screencast, that was helpful!!!
stevsmar13
welbot
It would be nice to have point to point movement for attached canvasses. Given the functions in the normal movement tool, shouldn't really be too hard to just apply the same movement options to canvasses as well right?
