Assembly and sub-assembly problems.
Assembly joints orientation and positions are not correct when bringing an assembly into another assembly.
The joints are perfect in there own enviroments.?
I opened aforementioned assemblies in an Inventor assembly enviroment and all is well?
I know the top down design is at the moment the prefered Fusion stratergy, but this design has Many parts. (scale steam engine).
Thanks All
2 Comments
TrippyLighting
On the odd chance that your workflow is in need of an update I suggest you post your design (export as .f3d, zip it up and attach to post ).
That would allow Autodesk folks or more experinenced users wheter there may be a bug at play or suggest a better workflow.
promm
Status changed to: RUG-jp審査通過
sharpy0,
What you are mentioning in your idea is a bug.  If you are still having the issue please email support at support.fusion360@autodesk.com.  You can also post to the forum.
http://forums.autodesk.com/t5/design-and-documentation/bd-p/124
Cheers,
Mike Prom
