Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Architectural/Feet-Inch Unit in Drawings
The Architectural/Feet-Inch unit is available for models but is missing from Drawings of those models. All units that Fusion 360 supports should be available in Drawings.
28 Comments
Yes! I need my drawings on a title block and in units of feet. Please add this.
keqingsong
Status changed to: RUG-jpåÆ©ęŸ»é€šéŽ
Thanks for your idea! We have this in our backlog but not sure when we are going to get to this since we have higher priority projects currently in the works. Since we aren't confident of when this will happen, we are archiving this idea for now.
I am also interested in this feature.
Absolutely!  This wonderful tool becomes almost useless for Architectural use without this ability.
Mike
KerryHarrison
Please add feet in drawings. We need it for building drawings. Thanks!
shawnbar4
Community Visitor
Yes, need architectural format in drawings
daveBT5BH
We GOTTA have this function!
JetForMe
 Why is this archived? I can't upvote it.
JetForMe
Does archiving prevent it from being upvoted? That's a pretty crummy way to prevent people from indicating their support for it. It's not hard to think you're hamstringing Fusion 360 because you have other architectural products.
derekXH6LZ
Please add support for this! It is critical in my opinion. Time saved using this awesome software is lost converting to feet and inches on the drawings.
spongman
i understand that you don't want to undercut the autocad market, but it's kinda lame to leave this out.
 I don't exactly understand the point of this forum. They archived this feature requested because it was a low priority. How will low priority feature requests gain support if they hide them? For that matter how can any feature request become a high priority if they hide all feature requests that aren't already a high priority? I hope that I am wrong, but it seems as though the point of this forum is just to make users feel like their voices are heard without actually listening to users.
This seems like it would be a simple feature to add since it has already been implemented in other Autodesk products.
@keqingsong any updates?
JetForMe
@Anonymous I agree!
derekXH6LZ
Yes, Please revisit this! It is critical feature and one that would be used on a daily basis by many of your regular customers.
william.ezell
Community Visitor
I also need feet and inches in the drawings.
yanouk73
The problem is in the table and the drawing sheet, this have to be possible to change your mind and adjust from in to mm per exemple, pounds to kg or grams, if you have diferrents clients, they may want Imperial or ISO dimensions, it make no sens to have to restart fromn zera a second drawing when it just the units that need to be adjusted..
More games and prizes from the fusion 360 team.
I too really need this for architectural drawing. Hope you make it a feature soon.
danmen101
People also use Fusion to design parametric buildings/structures, please make Feet-Inches available in the Drawing environment, thanks!!
carcega
Any ETA on this?
Technology Administrators
