I'm missing the ability to sketch arcs using the following methods:
- Arc tangent to two lines plus arc radius
- Arc through two points plus arc radius
The usual goal is to sketch something that resembles a fillet, but without using the dreaded fillet tool which ATM breaks sketch constraints pretty badly. My workaround is usually to draw a circle and then chop off any unwanted sections till I'm left with the arc I need.
Also, regarding the first tool suggestion, tangent geometry ideally would be not only straight lines but also curves (circles, ellipses, splines, etc).
This was previously requested and archived due to lack of votes, but it was requested when Fusion 360 was not so well known, hence I'm requesting it again here. Original threads:
Create arc using two points and a radius
Allow tangent arc to be drawn on a line, not JUST the end of a line
Thanks!
