Hi to Autodesk and to you all,
this is one thing that really bugging me in Fusion. If you are in Sketch creating and if you use LINE tool, than you can directly from this LINE tool create ARC. That is standard. BUT, it does it only in one way. You can't create ARC in 4 directions as in other CADs. See below animations of what i think.
CORRECT way how it is done in other SW:
BAD way of how it is now in Fusion 360:![ezgif.com-resize (14).gif ezgif.com-resize (14).gif](https://forums.autodesk.com/t5/image/serverpage/image-id/450938i66D178F691B60301/image-size/large?v=v2&px=999)
- In Fusion, you can create only tangent ARC in the direction of the line. You can't go backwards. And that is bad 😞
