Allow the ability to extrude sketches without having to enable 'Show Profile'
I want to be able to extrude without having to re-enter the sketch and re-check the 'show profile' box.
In complex drawings, the constant highlighting of profiles is annoying at best, and interfering at worst.  I would assume this is why the there is a 'Show Profile' check box.
But latter when you go to extrude, if the 'Show Profile' is not re-checked, you can't extrude, and a novice like me can spend an hour  or two trying to figure out what's going on.
It would be nice if when you press Extrude, it automatically in the background activated the 'Show Profile' box.  And if there is a reason why someone would not want this to happen, add a checkbox to the Extrude command that allows you to Not show profiles from visible sketches that don't have the 'Show Profile' box selected.
This same request is archived from 3 years ago.
-Thanks
