Allow cuts and joins on inserted component
Currently, this cannot be done, although there is apparently a workaround by creating a blank component, and copying the body of the inserted component into it.
So its possible, but messy.  Perhaps this could be done automatically under the covers when inserting a component?
To clarify, the original component must stay as is, but it might for e.g. need a hole cut in it when it is used for a a particular purpose.
3 Comments
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
If you look online at the number of times a question has been asked about this, I think you will agree it was a bit hasty to archive it. Not everyone comes here to vote!
