When you add a user parameter the dialog has a layout like this:
| Name | HoleDia |
| Unit | mm |
| Expression | 3.3 |
Once in a design you're likely to use the same units for all the parameters, so whenever I enter a parameter I type a name, press Tab twice, then enter the size. To make it a little more streamlined could we reorder the fields so it reads like this?
| Name | HoleDia |
| Expression | 3.3 |
| Unit | mm |
