Add the possibility to select faces, splines or vertices by transparency
Would be nice to have the possibility, into Sculpt Workspace to select faces, splines or vertices that are behind the actual view by transparency, without having to turn the model this other side (Like in blender in fact with wireframe selection by transparency (shortcut Z))
3 Comments
Telliria
Just like in the model workspace you can select any face, line or point in the sculpt workspacy by holding the left mouse button over it. this will create a drop down list where you can select any item where you clicked. Hope this helps!
keqingsong
Thank you for posting your idea! The idea is now 2 years old and does not have many votes, so we are going to archive it. If this is still important to you, please make a new post with the idea included. You can follow the idea submission guidelines here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
