I'd like to suggest adding the ability to copy-past physical material and/or appearance attribute values from one body/component/surface, etc to another. This would allow a user to quickly assign the same material properties to like parts in a drawing, rather than going through the manual procedure of picking attribute values from the Physical Material and Appearance lists.
I see that there is a right-click > Properties > Copy to Clipboard option. But there doesn't seem to be a way to paste them once copied.
Thanks.
