Add shell combine operations
When working with shell type parts, the shell operation sequence is critical.  Too late and it doesn't work (part is too complex), too early makes the feature addition harder.
Addition (or substraction) of features/bosses on a molded component necessitates that you model the external enveloppe first, add it to the shell, trim it along the shell profile and then, substract the internal geometry to make this boss a shell of comparable thickness that is in continuity with the parent part.  This is tedius.  In CATIA, there is the possibility to make a union-trim that allows you to add a body while trimming the portion of the body that protrudes on the other sides.  This helps a little but still the substraction of an internal body is necessary.
I suggest an operation that would allow to select the portion of the union you want to keep (a little bit like in the sketches for which we no longer need to trim lines) and ask for a thickness (internal or external).
3 Comments
Going a bit further, it'd be great to have a few tools to cover the common basic stuff from molded parts (bosses; ribs; proper / variable drafting; uniform thickness; hooks / clips; etc.
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
