Add Shank Diameter Variable to Milling Tool Geometry
Would like to be able to set a milling tools shank diameter to a different size than the Flute or shaft diameter.
2 Comments
mill1
Fusion Idea Shank Diameter.pngThis works better 🙂
HughesTooling
Try experimenting with the Shaft tab. Set the Flute and Shoulder the same on the cutter tab.
