Add Properties to timeline context menu
Sometimes I need to know some info about a feature in the timeline, Extruded distance for example.  The only way I know of to see this info is to right click on the extrude icon in the timeline and select Edit Feature.  Fusion 360 sometimes needs to do a lot of calculating before it can open the edit dialog box.  I'd like to have Propertied added to the context menu so it just shows a dialog box with the settings for that feature, no editing. I assume this would be easy to retrieve and wouldn't require all the cpu calculations that the edit dialog box needs.
1 Comment
promm
Status changed to: RUG-jp審査通過
SGoldthwaite,
Thank you for your idea, this is getting archived due to lack of votes.
Cheers,
Mike Prom
