Add operator overloading to Points and Vectors
Some basic operator overloading would make working with points and vectors way easier.
Here an example of adding a vector scaled by a factor of 3 to a point:
Now:
tempVector = originalVector.copy()
tempVector.scaleBy(3)
resultPoint = originalPoint.copy()
resultPoint.translateBy(tempVector)
With operator overloading:
resultPoint = originalPoint + originalVector * 3
Here would be my suggestion. It will use Points and Vectors interchangeably as they are very similar:
Vector1 + Vector2 = Vector3
behaves like:
Vector3 = Vector1.copy().add(Vector2) Vector1 * number = Vector2 behaves like:
Vector2 = Vector1.copy().scaleBy(number) Vector1 - Vector2 = Vector3 behaves like: Vector4 = Vector2.copy() Vector4.scaleBy(-1) Vector3 = Vector1.copy().add(Vector4) Vector1 / number = Vector2 behaves like:
Vector2 = Vector1.copy().scaleBy(1/number) Vector1 += Vector2 behaves like:
Vector1.add(Vector2) Vector1 *= number behaves like:
Vector1.scaleBy(number) Vector1 -= Vector2 behaves like: Vector3 = vector2.copy() Vector3.scaleBy(-1) Vector1.add(Vector3) Vector1 /= number behaves like:
Vector1.scaleBy(1/number)
I would assume the previous suggestions to be universally accepted. Here are some more that would be useful:
str(Vector) = "[x, y, z]"
behaves like:
def __str__(self):
    return "[{:g}, {:g}, {:g}]".format(self.x, self.y, self.z)
reason:
This makes debugging easier as it returns the actual components of the vector instead of just the Class. Class type can still be accessed.
abs(Vector) = length
behaves like:
def __abs__(self):
    return self.length
setter method for Vector.length
behaves like:
def _set_length(self, length):
    self.scaleBy(length / self._get_length())
Vector1 * Vector2 = dotProduct
behaves like:
dotProduct = Vector1.dotProduct(Vector2)
