Add new fields to Extrude command input UI for Material / Appearance
When Extrude gets invokes two new fields get included in the Command Input, Material and Appearance, which would display the current values that will be used.  The user could select these fields which result in launching either the Physical Material or Appearance methods allowing an override of the defaults when the Extrusion is performed.
