Add .max to the list of Import file extensions
I do not see an option to choose the file extension for 3ds Max (.max) on the Import -> Choose File -> All supported files pull down
menu.  Would you please add that option.
Thank you,
Michelle Lederer
4 Comments
keqingsong
Thanks for submitting your request! I will keep you posted on the progress of this request as we review with our extended team.
keqingsong
Status changed to: オートデスク今後検討
schneik-adsk
Max data is all polygons and has some challenges converting to solids. We are working on support mesh data directly in Fusion3 60 and are looking at STL, OBJ, and SketchUp models first. Max is interesting but lower in the list of formats. What kind of data do you have in Max that you want to use?
buzzkross
This one is harder because MAX makes polygons, rather than solids.   We are working on polygon mesh editing but that will take some work.  This will likely happen later.
