add a "?" beside each command for help
I am a new user and finding your help very frustrating.
Finding the right help concerning a command, is very very difficult and time consuming.  I have to believe that all the commands are documented to how they work and what they do.   My suggestion is to put a "?" beside each command , If pressed it takes you to a description as follows:
1)general description of what the command does and its uses.
2) video or screen shot of a simple use of the command with example
3) link to more topics / forum/ getting started videos etc.
Item 1 and 2 are considered basic documation of all programs, but seems to be missing with your help functions.  It looks like there has never been an effort to document your program properly(or maybe your help does not take me to the proper documentation).  Instead, your help seems to be a series of answers to peoples problems , plus a few getting started videos.This is OK ,and very helpful but not much good to a beginner trying to learn each command and its uses.
3 Comments
HughesTooling
When you select a command and it's dialog is visible there's a "i" that give you help and a link to more help in your browser.
Mark
docara
Wow! Fusion has a help facility - You jest sir!!!!
Thankyou,
I see now how help works.  I am an old timer, and sorely miss  4" thick reference books that use to come with new programs .(several of them usually)
However I do enjoy the $1000 to $1500 dollars saved.
Great work on this program.
Thanks again.
