Add a new 3D Printer in Print studio
I own the Prusa i3 Mk2 3D printer ad I'd like to add it in Print Studio. I haven't found ant botton where I can add or costumize a 3D Printer. Do you have any advice for me? Thank you very much
Mirko
3 Comments
jel111
Did you see this link? https://forums.autodesk.com/t5/inventor-forum/inventor-2016-adding-a-3d-printer-type/td-p/5615245?no...
I know this was a long time ago but I am trying to do the same thing and cannot find that file. I used Spotlight to try and find it and it doesn't show up. The guy on the other post wasn't very cool so I thought I would ask you what you ended up doing. It would be nice to have everything integrated.
I own a Prusa i3 MK3 3d Printer. I am having a problem sending the STL file to this printer which uses Prusa Control and Prusa Scl3r. Now when I point the fusion software to the exe the Prusa Control starts but does not go any further. I have asked Prusa to look into this problem but they are telling me that the fusion 360 stl exporter is at fault., although i have told them it works perfectly for Repitier host. There are a large number of 3d printers from Prusa using this software. Would someone from Fusion / Autodesk look in to this problem?
Best Wishes, Paul.
Open the Printer dialog box. After installing and starting Print Studio the first time, if no USB printer is connected to the computer, you're prompted to select a printing option in the Printers dialog box. In the Printers dialog box, select the desired printing option. For further any query do visit at Canon Support as it has a huge range of solutions.
