Hey Fusion Developers,
It would be great if the X Y Z Delta measurements on the respective axis would rotate around its axis, depending on the direction of view.
Whenever i measure the distance between two points with the 'measure-tool', the X Y Z Delta measurements are written in a certain plane of the origin coordinate system. If i look from another side/angle/direction, i look on top of the measurement. being that a 2D entity, it vanishes as a line in the same colored Delta axis line. (see attached screenshots)
Can you make these measurements writing planes rotating themselves to be as perpendicular to the direction of view as possible?
That would be great...
Thanks!
