Ability to show parameter names in the sketch view
If I have based a dimension off of a parameter, in addition to seeing the final value displayed in the UI, I would also like an option to see the parameter name.  This way I can quickly scan my sketch dimensions to make sure the parameters are all correct, as well as see the parameter names as a reference when adding/using them in other dimensions in the sketch. (Currently, you have to open up the parameters window, remember the name, then close it again since it's modal to the design.)
4 Comments
think I would be happy with just this:  In the sketch view a dimension would show it's value but would also have some kind indicator telling that it is defined by a parameter instead of just a directly input value.  It seems to me that showing both the value and the parameter name could get pretty messy.  But I could be wrong.  It would certainly be nice to be able to easily double check that all the appropriate parts are set to the correct parameter.  Perhaps it should be a toggling behavior.  You can set it to globally show actual values or parameter names.
I too am looking for similar display. Is there a toggle somewhere?
colin.smith
This item has been archived due to a lack of votes. If you feel this item is important feel free to create a new idea station item.
colin.smith
Status changed to: RUG-jp審査通過
