So if design history is turned on, you create an offset construction plane, then you can go back and edit the feature to move it.
But if you created it when design history was turned off? You can't go back and edit it in any way, from what I can tell.
This hit me yesterday. i was in a rush, didn't realize history was off when I create a few construction planes to split my body a few times for color brake-ups in keyshot (the rendering here kind of sucks for now). I realized I didn't have history on after creating those planes, but I thought, "oh no big deal"
I thought one of the breaks should be just a bit different, so I went to move the construction plane that is cutting my object. Move didn't work. There was no way to edit the definition. I was just hosed without having to redo that work. Well, I needed those renderings so I just said "f it, it's good enough." I don't like to say that something is good enough when I don't mean it.
So it would just be nice to be able to move a construction plane that doesn't have history attached. I mean, what's the big deal? It doesn't have history, but things May have history from it. Just record a new world position from the origin right? Everything has that much history, so when history is off isn't that the only thing really recorded?
