Ability to make any shape hole
The ability to make any shape (at least a square and triangle) as easily as a circle hole.
3 Comments
if you want to make any shape hole then you always needed:-
1.) to select the face on which you want to make hole
2.) then after selecting the face you need to go to 'create sketch'(sketch--->create sketch)
3.) 'now make any possible shape as per your desire' with the sketch tools
4.) now use extrude (or pull) tool in create panel.
5.) extrude your sketch to a desire depth as needed.
Simple to make holes as you need
OR
***steps to follow
1.)go to sketch panel and choose 'create sketch(sketch panel-->create sketch)
2.)now choose the face on which you want to sketch your desired shape of hole.
3.)sketch the shape of hole and extrude it.
Simple
colin.smith
This item has been archived due to a lack of votes. If you feel this item is important feel free to create a new idea station item.
colin.smith
Status changed to: RUG-jp審査通過
