First, thank you to the Fusion 360 team. This is an awesome product. One feature that would help someone like myself would be the abilty to add and edit wires. Being able to easily model and iterate on wire routing in a product design would be great. Specifically I'm thinking of being able to set a start and end point for the wire. Then specify the length and diameter. Fusion would then generate a body that could be dragged around and would flex or bend. and optional parameter like minimum bend radius would be helpful.
